Center dash light 1974 flh
The dash has three red rectangular lights on it and two directional signal green lights above it on the dash The left is high beam, the right is oil and im assuming the center is neutral which I don't know if it ever worked or not. But after a good run today, it comes on and stays on in or out of gear. Just incase it was a voltage light I tested the alternator and its putting out 14.2 running so I know its not that. If in fact it is the neutral light, why suddenly would it come on and stay on? The bike has always started in or out of gear. When I shift it stays on as well. Goes off when I turn off the key.
Any ideas?
Randy
randy
Any ideas?
Randy
randy
Definitely some kind of short, when I wiggled a few wires underneath it went out. Where does the wire to the transmission go. I cant find any place where a wire goes on it. Not to mention I don't recall ever hooking or unhooking a wire from the tranny when I powdercoated the frame. its a ratchet top set up, if that's what its called
randy
randy
