Lifter wheel bearing failure
I have an 82 FL that had a lifter go out. The wheel bearings are disintegrated on the lifter. I'm worried about the bottom end. I just had it redone and its only got about 10000miles on it. Is there a trick to get out all the metal out of the case from the bearing? Is the bottom end shot? I put a magnet in the cam housing and nothing except for little metal dust pieces came out. Checked the cam and it looks good.
Jeff
Jeff
two things - the very small rollers usually brake into dust and they make a feed side magnet metal catcher kind of filter for the oil line going into the oil pump - for this i would install one and you can just pop it apart draining the oil and clean it out after a ride - we had in the past installed them even on rebuilds - you need to look at the rollers on the other lifters that does not sound right if you have had the unit overhauled -
they installed china rollers or they never installed new USA / japan ones -- USA torrington rollers it will happen but in very high mile motors 20 30 years of use - berry common china junk failing 1 or 2 years later
Thanks for the reply. So looks like I ll take apart the cam housing cover and see if I can any of the bearing parts. All the inner of the bearing are gone so you think I would find something.
When I had it rebuilt they didnt replace the rollers.They never ask and I didn't even think about it. In fact one of them is miss matched so who knows how old they are. Dumb move and I have learned my lession.
Thanks for the response. Do you know where I can find this type of oil filter? When I stuck a magnet in the bottom of the cam housing I did get some metal dust so Im hoping they did break up.
if you need new real rollers put on your lifters let me know we stock the USA or japan ones that are the only ones we use
