Color codes on shovelhead cams
Received 47,779 Likes
https://books.google.com/books?id=-k...0codes&f=false
P.S. You might ask to have this moved to the Shovelhead Section
Thanks for the replies. I've been a automotive mechanic for 47 years, and I'm learning from the bottom. This bike ran good before I let it set for 11 years. I'm determined to get this cool old bike going again. Uncle Larry, I'm new to this site and how would I move this to Shovelhead Section ?
H is a stock shovel cam, 1976 was the last year for the gear not to have a groove in its face as they changed it - harley early and grooved late cam gears are color coded and have a different diameter, i believe 5 or 6 were available BUT you can remove your cam gear and install it on a new cam or replacement - crane had but went under and they made new H cams, harley does not any longer - some times flea bay has New old stock
Andrews cams has a replacement in the A cam it has just a taste of more lift and duration NOTE - rocker arm ratio for a shovel is 1.43 so the cam looks big but it is not - shovel stock i forget but think its .390 or around .400 in lift and only 200 degrees of duration
the A cam idles exactly like a stock bike but has a better pull in 3rd gear getting on a hwy all cams for shovels come with a red gear and its smaller so you could have a ticking sound at speed as you have a larger black gear < i know i know but its how they do it
