Drag pipe recommendation?
Old 07-30-2015, 06:25 PM
Baird's Avatar
Baird
Baird is offline
Received 1,060 Likes on 436 Posts
Looks GOOD! Watch it tightening on the studs too much or you'll drag 'em right out of the aluminum head. I agree, don't double gasket get them, tighten at the head and make them fit to the frame, go for a ride and tighten again.
  #32
Old 07-30-2015, 09:59 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
I use studs in my exhaust mounts. I also recommend [especially with Chiwanese Exhaust] mount the pipes to the studs [or port] such that they seal all the way around, and look at where they are pointing...
Now you gotta figger out how to get them pointed where they belong while still maintaining that even sealing surface.
Good Luck.
  #33
Old 07-30-2015, 11:39 PM
72_shovel's Avatar
72_shovel
72_shovel is offline
Don't double the gaskets they will just blow out faster and use Permatex Ultra gray not the red ****. Trouble sealing is directly related to not being mounted or aligned right on the rear bracket , it's not uncommon to either have to bend it a little to tuck or raise the pipe a bit or add a washer or 2 between the bracket and the pipe on the T bolt to get everything clean and straight and from what I'm seeing in the picture that front pipes is off a bunch .
Don't be afraid to get in there and tweak things none of the aftermarket stuff bolts up true and straight out of the box.
Actually, the front pipe is sealed pretty well. I'll see what I can do tomorrow after work.
  #34
Old 08-02-2015, 07:48 AM
glidein wide's Avatar
glidein wide
glidein wide is offline
Looks good, too bad you let them talk you out of getting the power cones in the J& P CYCLE catalog, because they do make a difference. Just trying to help a brother....
  #35
Old 08-02-2015, 08:20 AM
Racepres's Avatar
Racepres
Racepres is offline
And we can verify this how??
Like saying those damnable Bolts stuffed into drag pipes is a good Band-Aide!
I have my friends ride a Bike I have here with a Proper Exhaust, quite often, so they learn how a Proper Exhaust acts.
However, the Sound will never really be the Same.
BTW If your Seat of the Pants is telling you your exhaust is "better", then you will need to keep it, no matter what, But, I ain't running it.
  #36
Old 08-06-2015, 06:07 PM
glidein wide
Damn bolts are not precisionly machine as the cones, really ? He's the one that wants drags instead of your "proper"exhaust, I only suggested the cones to make it easier for him to tune.
You could run it or dyno it with and without the cones, not only see the results but feel it,that's how I know. Plus the drags sound better WITH the cones in, ... IMHO
Would never claim my exhaust is better than anyone else's......
  #37
Old 08-06-2015, 07:55 PM
Racepres's Avatar
Racepres
Racepres is offline
My dyno is 1/4 of a mile long, and I can prove cones are not gonna help ya here.....In the real world.
But, if you are convinced that they work...Nothing in the world will change your mind. So....You need to run 'em.
Enjoy....
Edit:
BTW If you don't think we Have tried every Pipe, and Modification Known/Unknown to man....Well, Walk a Mile in My shoes!!!
And No those are Not OK nor Optimum Either!!!
  #38
Old 08-09-2015, 09:31 AM
pjb's Avatar
pjb
pjb is offline
I've run both with and without cones, on Evos and Shovels. I can't tell any difference.
  #39
Old 08-09-2015, 01:59 PM
glidein wide
Thanks a lot pj, !!!! Some people can't pick up detail, that fine line,"did you wash or wax your car?" Uuuummmm cuz I can't tell, well I can.
If the op was asking about exhaust to run1/4 mile then I wouldn't have posted anything at all,Iassume he is not racing it,different tune,you know that I hope race man,you can **** farther than me so under my rock I go.
Op must be laughing his *** off.!!!
60Gunner
Exhaust System Topics
03-11-2019 04:27 PM
Wakko47
03-21-2013 09:18 AM
joechiu1024
10-04-2011 08:59 PM
Nate77
04-26-2010 03:19 PM
kata
06-19-2005 09:05 PM
Quick Reply: Drag pipe recommendation?
