Starter issue on '77 electra
I installed a lever actuator to replace the solenoid on the primary, and it works very well (after lots of shimming), however the wiring they sent with the manual starter lever was wrong, so I'm currently jumping the starter across the two large poles of the starter relay. I'm just wondering how the starter relay is normaly engaged? I tried adding both positive and negative current to the "S" pole on the starter relay and couldn't get the relay to click at all. Brand new starter relay BTW, just wondering if I got a bad one. I haven't had a lot of luck finding info on what actually changes the relay to closed. Let me know if you have any ideas, kind of a pain having to hold the lever and jump the terminals on the other side of the bike to start it.
Have you eliminated the Starter Relay??
Does your Manual relay Bring the Bendix in....I'm very confused now!!!
yes, the lever engages the starter gear into the ring gear. http://www.jpcycles.com/product/381-946
It has a single wire coming out of it, and it's a ground and I wired it as it was supposed to be with the included relay, and it didn't work.
So...The Ground must be applied to a Starter Relay, which fires and applies the 12v to the starter motor when ya pull the lever to engage the Bendix...I think I got it..
Don't know why I would do it??? But, I got it.
Put yer Solenoid back and go back to the Feeler on the Solenoid...eliminating all the rest of the Starter circuit!
Unless you have a Mechanical problem with your original components...Fork or Solenoid.
Odd that they use a Ground, but...was it me I would use two relays...the small late model one controlled by the Ground you have from yer "Lever" have the small relay then Fire The Large [solenoid-Like] Relay to apply 12v to the Starter....Done!
That's exactly what I have! I can't figure out how to fire the starter relay. I can make the small relay click all day, but I can't get the starter relay to close on it's own. It has two pins, marked S(switch) and M I think. Neither one of them makes the relay click when either + or - is applied to either terminal.
