Starter just spinning
Went riding, stopped to check location and went to start the bike, just a bunch of whirring.
New to bikes period. Very rusty at mechanicking, lol. So much so that I got the bike home and started to take apart the solenoid cuz it looks like a car starter. I think I've stopped before causing any damage. Disconnected the wires, two screws and pulled the solenoid. I'm at the rubber boot with a rod sticking out of it. I will be putting that back together today. Just got the manual, which made me realize that it wasn't the starter.
Anyways, any tips or advice before I just start pulling **** off?
you can test the solenoid by jumping two of the poles, the one that sticks out the furthest, and the small screw next to it, if the solenoid is good, it should pull in. I would still pull the primary cover, it's really easy and it will give you a better idea of what the mousetrap setup looks like.
I would just use an old screwdriver to short the two terminals of the solenoid, if you have it connected to the battery. The starter bendix assembly inside the primary is called the mousetrap sometimes. If you don't have a service manual for the bike, get one, or you can download the pdf version here: http://hd-vintage.cbssm.com/index.html#1980 There's also free downloads if you google enough.
I do have the manual. Just got it yesterday. It's the only reason I know I took apart the solenoid. I thought it was the starter. I'm going on 20 year old car knowledge and it looked like a starter, lol.
I can hook the wires back up and see what it does. I got some pics while i had it apart, here there are just for ***** and giggles.
Is that the plunger? It moves all around, spins, pushes in and spins, doesn't grab on anything. Don't know if that's how it should be
The solenoid.
The solenoid.
