Rear Wheel Off Center
I took my 73 FLH for a ride yesterday. Started off ok, but after about a half hour I started hearing a funny noise when I went over good sized bumps in the road. Sounded like the rear tire scraping, and it was. The left edge of the rear tire is scraping on the fender sometimes when I hit bumps. I put the bike on the lift and the tire sits much closer to the left than to the right. Started it and put it in gear while on the lift and the wheel appears to be spinning true. I loosened the fender struts and that seemed to help a great deal, but when I tightened the left strut back up, it did it again. I have some stainless washers, so I may try to shim it a little. Any other ideas? Thanks.
Thanks for your reply. I've seem them slightly offset too. It looks like it has the shorter shocks, so that may be it. The tire doesn't look oversized, but I don't know what the stock size for that bike is. I shimmed it slightly. That helped a good bit, but it still does it on large bumps. I tried to adjust the shocks to increase the preload a bit, but I can't budge them. Maybe I need a different type of spanner wrench. Mine is the half moon type. Maybe I need the one that looks like a pair of pliers. Thanks again.
Thanks. Tire size is correct. I guess I'll order the pliers type spanner wrench and try to adjust the shocks. The bike sits pretty low. I measured the shocks and they look to be 11 inches. If I got new shocks, any recommendations for longer ones? Mine are the chrome shocks and they have chrome dome that sit on top and has a clamp around it. I would like to keep that style. Thanks again.
Many of those bikes have the fender biased towards the left from what we've witnessed.
From what we suspect, the frame jig/fender mounting holes in the fenders were not correct.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
yes - but the sprocket alignment can be handled using spacers as well - either move to a non-dished rear sprocket and shim left as needed - or shim what you got - of course - being an ironhead guy - I offset the rim from the hub by adjusting the spokes - ironheads have about an 1/8 offset - ferg
