Welded clutch hub studs - pics
I bought the BDL setup from a guy that did not use safety wire on his primary bolts - the bolts go loose and caused a bit of rubbin and gindin = the hub runs straight - in fact - now that I dialed it in - I can spin the hub with the clutch pulled and it spins like that video everyone posts when they show how a shovel clutch should "spin" - new bearings - aluminum frictions - straight drive plates - and stock release disc and pressure plate - the welds make this very tight - but then again - the hub is done if a stud breaks or I have other issues
anything2wheels
24
04-23-2018 10:49 PM
