Changing from a points ignition?
Old 08-31-2015, 01:09 PM
hyrax222's Avatar
hyrax222
hyrax222 is offline
I changed from points to Ultima Electronic ignition four years ago. I static set the timing and never needed to change it.
I am very pleased with it.
Old 09-15-2015, 09:46 AM
71_FX_Superglide's Avatar
71_FX_Superglide
71_FX_Superglide is offline
1st Gear
Hello all,
Recently picked up a '71 FX, and was considering making the change to electronic ignition.
What's the installation time/difficulty on one of these type systems? Also, can anyone recommend a good coil to use with the Ultima system?
Thanks!
-- Andy
Old 09-19-2015, 06:28 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 6,989 Likes on 2,814 Posts
A Dyna S dual fire has been in my Shovel since about 1998. Only change I made once was a Rivera advance unit and it ran like **** so I put a new stocker in and no problems since.
Old 09-24-2015, 07:07 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,518 Likes on 2,862 Posts
i only sell the ultima electronic in my shop no other - its reliable in 12 or 15 years i had one act up the led bulb burned out and they sent me a new one for free -- the coils are 50/50 you get a good one they are like any other - i also dont buy the kits that for a shop are almost the same cost as with out, but we know the coil is an issue - use the dual fire set up, any oem 3 ohm coil and your good to go or single fire we buy the dyna - in a shovel no difference can be seen going to more money single fire
the dyna s is a great no frills magnet trigger and yes the bearing advancer is a MUST have ( rivera = USA ) but only saving a small amount if you already have a 3 ohm coil -- the dyna s HAS to have a 5 ohm coil the same one you want for points or it burns right out with a electronic 3 ohm coil
you need to check what you have with an OHM meter
BassFace
Shovelhead
13
07-26-2017 02:53 PM
harleymark
03-04-2009 08:32 PM
badinfluence63
Shovelhead
08-12-2008 10:46 AM
badinfluence63
08-08-2008 10:07 AM
SPILF
10-01-2006 10:15 PM
Quick Reply: Changing from a points ignition?
