82 FXR Question About Rear Wheel Bearing Seals
Old 08-29-2015, 12:39 AM
atengnr's Avatar
atengnr
atengnr is offline
Default 82 FXR Question About Rear Wheel Bearing Seals
Started working on replacing rear brakes/rotors, and repacked wheel bearings. I noticed when putting new seals on that there is no shoulder that acts as a hard stop to position bearing seals. Anyways, after reassembling, I discovered that the seals are supposed to be pressed in 5/16" below the top of the hub. Is it critical that this be exactly right? I didnt check where I put mine, but I know that the spacer pilot diameter rides on the lip of seal. Should I take out spacers, and make sure the depth is exactly right??
Thanks alot.
Old 08-29-2015, 06:50 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,518 Likes on 2,862 Posts
they early hub had a snap ring and washer that install over the seal with captured spacer and you may have a later style - as long as the seal is flat to the end of the hub your good to go
Old 08-29-2015, 07:04 AM
atengnr's Avatar
atengnr
atengnr is offline
Yeah no snap ring in this assembly. In terms of the seal, the manual I have says to press seal in 5/16" below top of hub. Wondering how critical it is to get this exact.
Old 08-29-2015, 08:19 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
as long as it rides on an area of the spacer that is making full contact ( spacer to seal ) your good
Old 08-29-2015, 09:39 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,048 Likes on 1,507 Posts
And...May I add? It is Much more important that it be Flat...not "cocked" in any way. The best reason to have a positive "stop", which is not Provided.
PC12Driver
Shovelhead
07-13-2018 06:39 PM
525tom
01-16-2015 04:45 PM
Alumni
EVO
05-02-2013 09:46 AM
skos
Wheels/Tires
03-27-2009 10:02 AM
wsg
03-24-2006 08:59 AM
Quick Reply: 82 FXR Question About Rear Wheel Bearing Seals
