Breather Routing
you may have wear on the breather valve / the plastic one that causes leaks - well its what we see anyway , others think the 6 dollar valve is better then the metal one you can install in its place
to answer the question - we run a new hose - turn the fitting up not down and bring the hose up and over the top of the oil tank and back down again - on the chain drives we set it so any vapor blows on the chain - belt drive we set it so it goes to the low spot and add a filter in the center in the ground strap area with the cross brace
