Rear Chain Tension - 82 fxr
I never lube my chain. I use lithium grease. Pull the chain off, clean it in kerosene, wipe it off til it's good and dry then clean the sprockets and reassemble everything. After you have checked the tension and everything is buttoned up, paint the grease on with a cheap acid brush. Top of the rollers, bottoms, and both plates inside and out. Try not to get any of this stuff on you, it isn't easy to get it off.
Redo it when the chain starts looking dirty again or every time you change the rear tire.
carl
carl
