Oil line routing on 76 FLH w/stock tank.
Restoring a 76 FLH. Need oil line routing diagram for stock oil tank. My sifton oil pump does not have the nozzle for the small line going to primary. There is a port that has a plug in it. Do I use that. My original pump had a nozzle made into the pump. Any suggestions on how to do this would be appreciated.
chaz976 (04-21-2023)
Received 3,211 Likes
Oil line routing
Because nobody in their right mind would want to spray engine oil all over their swingarm and rear tire??? That's probably why aftermarket oil pumps don't have the screw. I quit using mine on my '77 when I bought it back in 1980. I also isolated my primary chain case so I wasn't pushing clutch material and chain tensioner material through my engine.
