Oil Line mysteries & primary oil level
New to this '83 Shovel, but not to motorcycle wrenching.
Scratching my head trying to figure out a couple of PO mods on this well running machine.
He 'closed' the primary to stock oil circulation so have a couple of clamped off hoses and one that is just open and dangling.
From the sketchy oil line pics in a Clymer manual, the open line appears to be the primary return line. OK...
What i think is the primary supply line is blocked with a bolt and clamp. OK...
The crankcase vent line also appears to be blocked. No line going to the air cleaner. I think it was fouling the filter.
So got a couple questions:
Is there a better oil line diagram online someplace?
Where should i run the crankcase vent line? i assume it is a good thing to do.
What is the proper level of oil in the primary? (sealed from engine oil line).
thanks in advance,
t
thanks in advance,
t
the crankcase vent line goes open to the air.
Many people use a small filter at the end that "collects" the oil
I guess you could also run it to the rear chain to oil it (I think the 83 pump doesn't have the chain oiler, not sure)
Oil in the primary is 6-8oz, or right until the oil touches the clutch basket
What oil? People use ATF, primary fluid, motor oil
Received 3,210 Likes
thanks in advance,
t
thanks in advance,
t
