External Oil Filter and Cooler
Old 11-28-2015, 08:01 AM
tpb857's Avatar
tpb857
tpb857 is offline
Default External Oil Filter and Cooler
I got my 73 FLH back in July. The motor appears to be all stock. It has an external spin on oil filter, appears to be a regular HD chrome filter. It also has what looks like a Jagg vertical oil cooler on one of the downtubes. The oil lines are looking kind of scary and I am going to change them this winter. I want to get rid of the external filter and the oil cooler when I do this, unless I'm really getting a significant benefit from having them on the bike. I'm is southwest PA and gets in the 80s in the summer, but nothing blazing hot. Would you keep them on? Thanks.
Old 11-28-2015, 09:37 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
No way I keep either myself....The stock in-tank filter is fine [I use the Perform drop in filter] Been fine since the mid '80's, I guess it will go awhile longer...
IMO one of the worst things you can do to a shovel is restrict the return oil. [right after restricting the Breather]
Old 11-28-2015, 12:00 PM
tpb857's Avatar
tpb857
tpb857 is offline
Thanks for the reply. Looks like I will get rid of them.
Old 11-28-2015, 12:17 PM
Racepres's Avatar
Racepres
Racepres is offline
While I'm sure there are many that will disagree...I would get rid of them if I were you...
Old 11-28-2015, 12:59 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,919 Likes on 17,474 Posts
Personal choice and the bike in question, bone stock close to original bike lose the extra's a heavy daily rider that's been personalized I like to run the external filter and in hot states the oil cooler too just for the added oil capacity if nothing else.
Old 11-28-2015, 05:25 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
Default Twizted
Ditto
Old 11-28-2015, 08:51 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
the filter - spin on is a full flow and restricts the same as the pro form - almost nothing
an oil cooler is 25 degrees cooler on average in traffic and down the road / actually a good idea and as twist has said having more oil to feed in and out is always a good idea
Old 11-28-2015, 10:05 PM
Racepres's Avatar
Racepres
Racepres is offline
Well..I can't see the filter being used from here...and I don't think I have Ever needed cooler oil...warmer sometimes, Never cooler.
And I stand by my statement that any restrictions in the return side...coolers included, are a Bad thing.
But...Like I said I only owned shovelheads since the mid '80's [continuously] maybe Mine will take a **** from not doin it right one day.....
Old 11-29-2015, 08:15 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
the late shovel oil pump has been used ( developed for the 80 inch motor ) and on every EVO Big twin till 91 when they changed the bolt pattern - not one came with out a filter
it is way easier to pump oil into and though paper then it is the small holes for the hydraulic lifters and that is only one if the small holes in any of the big twin motors
the restriction is far less - BUT having said that I do the same with any shovel you do / i am in the NYC area and traffic is the thing zero to 80MPH all the time it seems so an oil cooler on the stock or strokers is a very needed item - stop and go plus idle time at the Holland tunnel alone will scorch a piston and you have not even gotten into the city yet
Old 11-29-2015, 10:34 AM
Racepres's Avatar
Racepres
Racepres is offline
My statement about not being able to see the filter means that it may in fact Not be even for a Shovelhead...Twinkies take a different filter, and they should Not be interchanged.
the Feed side of the Shovel pump has No Problems pushing oil thru restrictions...like the lifters! The Return side...the one Shovels use the Filter in, do not do very good with restrictions...We had one guy with so much Crap in the return side [giant dual coolers with a mile of hose] that the poor thing could Not return oil...
If I lived where it was Really Hot...Montgomery, AL in July comes to mind! I would probably run a Cooler of some sort...close to the Tank as possible, for minimal hose, and keep the in tank filter...
I've been to SW PA many times...I wouldn't think a Cooler is necessary there..And remote Filters...if you have a Stock oil Tank, are a Waste of Hose, and unnecessarily restrictive....
I'll stand by the Validity of the Original advice given to the Original Poster!
All else...Do what ya want...
bmaier
03-08-2012 11:39 AM
mi2az
Oil Archive (no new posts)
07-25-2011 06:06 PM
07fatboycustom
03-14-2010 04:14 PM
obwhan
06-29-2009 02:15 AM
swipter
01-19-2008 09:34 PM
Quick Reply: External Oil Filter and Cooler
