Primary oil feed on dry clutch
Old 12-06-2015, 03:27 PM
Kees's Avatar
Kees
Kees is offline
Default Primary oil feed on dry clutch
Hello Gentlemen....so my 1984 FXSB arrived and all is great. I was going through the bike and I checked the primary fluid level. None in there but the chain was oiled....did a little digging and found that my bike is running a dry clutch with an oil feed from the pump and returning back to oil tank. My question is how much oil should be in there...it appears that none remains in the primary because the return hole is right at the bottom right of the inner primary. Your advice is appreciated. Cheers
Old 12-06-2015, 04:01 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,519 Likes on 2,862 Posts
the best advice one can give is leave it alone - if the chain is wet and the clutch does not slip - effen with that system and not being aware of how and whats going on would be a disaster
leave well enough alone
the factory book has a chapter on what goes on and how it works
Old 12-06-2015, 04:05 PM
Kees's Avatar
Kees
Kees is offline
Cheers John...don't worry I wasn't about to mess with it, I was just curious about the amount of oil that should be in there. I haven't managed to track down a workshop manual as yet.
Old 12-06-2015, 04:12 PM
johnjzjz's Avatar
johnjzjz
that late system will only have what you found the early system has more oil actually
same idea different way to do it from the factoy
Old 12-07-2015, 07:25 AM
LostInNM's Avatar
LostInNM
LostInNM is offline
Service and parts manuals are here: http://www.chopcult.com/forum/showthread.php?t=20835
My 83 FLH has the feed and returns lines blocked off and seeps oil from the 'wet' primary pretty badly. Preventing that was probably the reason HD went to the 'dry' primary system. Downside is a higher possibility of oil contamination.
Old 12-07-2015, 07:56 AM
johnjzjz's Avatar
johnjzjz
true - but every big twin made from 1965 to 1984 every model has the return system - many many many of them have seen well over 100,000 miles and using the original return - sure its iffy in how much debris gets sucked into the oil tank
once every couple years we remove the oil tank and wash it out when its snowing and i think it would be a good idea on a bike like this - but i have seen some with the oil tank spotless and its those that change the oil and filter at low miles between services
Old 12-08-2015, 11:43 PM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
I agree leave well enough alone. Change your oil often and the stock system will not give you any problems.
Old 12-09-2015, 12:46 AM
Kees's Avatar
Kees
Kees is offline
Yep doing motor and gbox oils now. ..
Old 12-09-2015, 04:38 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,515 Likes on 3,772 Posts
Does a stock 84 have a drip primary and the scavenge return system to the motor oil sump?
Old 12-09-2015, 11:06 AM
Kees's Avatar
Kees
Kees is offline
Yep mine does
Quick Reply: Primary oil feed on dry clutch
