Rocker Shaft End Plug
01-17-2016, 10:05 AM
I want to loosen these end plugs on my 72 shovelhead to replace the O-rings behind. Does anyone know what size allen these are? They appear to be 9/32 which is basically an impossible size to find.
01-17-2016, 01:16 PM
2 things - one its 5/16 the OEM allen socket and if you have some kind of Communist part on the bike that would be the real reason behind the leak
2 -- we use the nylon square seals not the o rings any more as they will always come back to leak again
01-26-2016, 03:37 PM
You might find a hex bolt in your 20 year bin, use it upside down with vice grips, or double nut and wrench, or even pipe wrench to break loose.
01-26-2016, 10:06 PM
^^ Extreme COB method...any hardware or autoparts store has individual allen wrenches...
V_twins
Shovelhead
02-09-2015 10:09 AM
harley_jeff
Exhaust System Topics
04-14-2012 05:09 PM
Woodboot
Shovelhead
06-26-2010 09:10 AM
pyro
Ironhead
07-06-2009 11:42 AM
Calwoodbutcher
Ironhead
07-19-2006 12:54 PM
