Can I shim rear mount
Hello everyone!
I had just recently acquired a 75 ShovelHead with S&S 74cid(?) big bore stroker motor. (Of course the more I dive into this the more I find that the previous owner didn't know what he was doing and also ummm stretched the truth)
Sooo as the can of worms explodes I noticed I don't have any clearance on rear rocker cover to seat post.
What I'm tossing around in my head is can I shim rear motor mount 1/8+\~ to gain clearance and if so what am I in for? I figure I'll have to shim everything else too and don't want anymore issues or am I stuck with replacing seat post with smaller diameter DOM tubing?
Ty for all advice! 🤔🤓
Ps.... This all started with chain being loose and fender starting to rub tire! Swing arm bearings where bad and of course I'm going to have to put bushing in swing arm pivot bolt mount on right side because it's oblong! Grrrrrrr like I said can of worms!
way too little info - if its a belt drive no issue - if it has an inner primary the cracking has not started yet
pictures of that you are seeing
modding the frame is an option
checking deck height to see if you just have china jugs ( you did not say ) and machining will help
pictures and more info it sucks so type out every thing you did not add
That's pretty common seems more on mid seventy bikes it just depends on how things stack up, all you need is enough clearance to slip a credit card or about 1/16 inch between there, a little movement here and there when assembling a motor can make a big difference I would file the rocker box before getting into messing with frame if it is a stroker and you raise it any more you may not be able to get the rear head off without pulling the motor, to much voodoo science when you change something like that
ZachsdesignZ
02-01-2019 05:21 PM
ZachsdesignZ
01-30-2019 07:47 AM
