Hand Controls for '83 Shovel?
Hey guys
Looking to swap out my hand control for some new ones. One side is a bit stripped and won't tighten all the way and the switches are all rubbed off, etc. I just thought some new ones (or vintage ones) would look and work better.
I have had a hell of a time finding ones that are compatible with my '83 FXSB and to add to the struggle, the new bitchin' buckhorns I just threw on there are non-dimpled, so I need something compatible.
Can anyone send me a link to ones that will work?
Hey guys
While lots of Folks like the later controls...I still like the Compact, stockers...Even the little stickers are still available [gotta search] and a Bit of Paint or Better Yet, Polish...and they are nicer than any out there...In My Eye.
The following 2 users liked this post by johnjzjz:
Racepres (03-29-2016),
TwiZted Biker (04-02-2016)
^^^ Thanks for the reminder...I buy every ragged out set of switch housings I see at Swaps...Never gonna fool with Chiwanese switches for the '73- '81 switch housing again...And Not the Housings either!!! The originals were pretty good aluminum...some modicum of attention and they are Dandy..
I guess my other option is to dremel out the control pod to make room for the wires. There's a step by step tutorial here:
http://www.chopcult.com/forum/showthread.php?t=4847
For now, I just put them on kinda jenky to see if I like the bars and everything works ok, just not not flush.
Received 4,896 Likes
Spend the time to drill out the bars and run the wires internally. Looks 100% better and you do not need to dremel a good set of controls. You do it that way, next year you will want to run the wires internally anyway and will need new controls.
One oval shaped hole under each control and then a large oval opening in the middle of the bars facing down towards the trees. You said you are using buckhorns, super easy to pull wires through smooth bends. T bars, that is a whole different party.
Dude, not on my bike!!!!
