Oil-related questions
Hey guys... 1984 FXWG Shovel "Custom" (that was model, not referring to custom work), purchased in 1990. Has primary chain and secondary belt drive with 'dry' primary, [original setup, not sealed, 'dry' clutch].
1. Am replacing oil lines -- is there a way to replace the 3 hoses going to inner primary without taking the inner primary off??
2. Am getting what I think (by the smell) is a gear oil leak. After days of trying to track it down, I saw a tiny drip coming off the bottom of the secondary belt drive sprocket, right there where it sits behind the inner primary... the drip comes off the sprocket and falls on to the return line down on the primary... Any guesses where this might be originating from?
ShovelGirl (04-25-2016)
it could be worse then that, as it is a 4 speed bike, and the bushing inside of HI gear wears out causing an opening to the gear oil and no amount of seal changing will fix it, you need to remove the gear box and strip it to the screws as HI gear is the first thing installed inside an empty transmission to fix it correctly -
inner primary needs to be removed to insure your lines are correctly installed - but 2 will come off and on >>> but its a thing to do and in the end easyer to remove the inner primary, to bad you on the other coast we would give you a lift and tools and have at it
Yeah, I continued researching and have read as much... watched a guy take off his inner primary on his 2006 Dyna WG on YouTube to replace one of the seals on that shaft.
That's interesting as I read another guy who tried all the usual fixes (replacing all the seals) and nothing worked for him. Maybe that was his problem. I hope it's not mine. This bike has super-low original miles (23k).
I believe it. I have looked at it from every angle and aside from the return line which is at least somewhere reachable, I don't see how I can reach the others... I can't even SEE where the oiler meets the inner primary.
What a super-kind gesture. Thanks for the thought! Well, I am replacing the main oil lines for sure (to and from cooler, filter and tank)... the ones going to the primary might have to wait.
BTW, to eliminate the possibility of more than one leak, I shoved a wadded paper towel up into the space next to the belt sprocket to stop that from weeping.... and sure enough there was still a drip coming off the bottom frame... looking with a flashlight I noticed it was weeping from further forward b/c the frame was shiny back to the point where there is a cross-brace in the frame, just about even with the center of the primary.
Boy do I wish I could walk under that thing with a GIANT LIGHT.
Thanks guys for the feedback.
we use a big mirror to see whats going on, and a flat led cheep one from wal mart and for a car 23,000 miles is nothing but the original trans date for that type of gear box is 1936 and lots of parts are still the same even in 84, the bushing in the gear is the same type the gear is a little bit different
in the end you will have to have it looked after, as the leak is not going away and like i said about the seal - if you decide to have a seal changed do not be disappointed if it comes back in a week or so
ShovelGirl (04-26-2016)
the 4 speed unit is a good strong trans and like a timex watch - if someone has put in a GL 5 gear oil to it the brass bushings will wear out quickly - its an old school unit and new yadda yadda oil for twinkies is a no no - originally harley used 50W engine oil in them then 85/140 gear oil GL 4
while i have used saddlebagrails replacement seal spacer with the o ring inside of it and have them in stock - it is used by us in a new manufactured transmission to increase the life of the unit - not after its worn to the point of leaking
http://www.caimag.com/wordpress/2010...real-solution/
But I am getting a real education here and appreciate it.
