Blue silicone pushrod seals....
NEVER AGAIN !! ...I replaced my Solid lifters with the Vulcan Hydraulic Lifter & Lifter Block Kit and it came with the Blue silicone pushrod seals and because I have heard good things about them I went ahead and put em in. Huge mistake, I didn't make it 10 miles and sitting at a stop light I could smell oil and look down, oil spitting, leaking everywhere, turn around go home and pop the covers off and the seals are up in the tubes and feel like mush. So after I clean the mess up I put the cork seals back in and all is back to normal. What a pain that in the butt that was !! Live and Learn I guess...lol
And by the way, this bike will not be seeing solids again, the hydraulics are way quieter and make the ride much more relaxing
Could be a mix match on the tubes maybe I've seen a couple that was the issue with, haven't had a problem with the rubber ones yet myself. Thing I do know is all the parts have to clean and dry on the mating surfaces when you assemble, any oil and the silicon ones will move on you.
Aside from that how you liking the lifters ? What cam you running ?
I am loving the lifters..nice and quiet
I am running your favorite cam the Andrews BH...lol...My inner cam bearing went and the bike ran really good with that cam and figured I'll keep it simple and put the same cam(a new one) back in it. And I'm getting to be quite good at wrenching on this old dog...now I sound like my wife... lol
like twisted said about rust and being clean - the tubes springs over 30 plus years loose their tension - adding another cork in the front exhaust makes it as tight as the rear intake
it is a crap shoot on the seals with the black or blue rubber < and they again are different then each other - or using the original cork all will and can leak
adding spring washers and or a second OLD flattened cork to the tube set does work as well as fresh springs
