FLH Battery Tray and Battery
Old 05-13-2016, 12:58 AM
vanmor's Avatar
vanmor
vanmor is offline
Default FLH Battery Tray and Battery
I've been thinking about going with a FLH battery setup for better cranking power.
Then again, there are these smaller batteries that are supposed to be pretty powerful in a small size. Lithium batteries and what have you.
Thought my 88" stroker could stand the extra starting power.
Old 05-13-2016, 07:43 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,049 Likes on 1,508 Posts
You won't be happy...The Original FLH Battery is Large, and that's all!!!
The YB16B size [Superglide] can be had in AGM with more than 300 CCA, and The size is More than adequate with Li-on types.
To change. The pipes must clear the larger Box. the Starter mount for the Tray is Generally for the Prestolite Starter, or needs to be fabricated for the Hitachi. [or vice-versa I need to check that] and some rear fenders don't clear the Battery box anyway.
I have gone the other way!!!
Old 05-13-2016, 10:21 AM
vanmor's Avatar
vanmor
vanmor is offline
I have the Prestolite starter. I had it rebuilt and wanted to stay with it for now.
I noticed the FLH box used a different bracket. Guess it has to be to take the bigger battery. Didn't think about fender clearance.
The guy that rebuilt my starter also sells batteries. He is very reasonable price wise plus he has a great selection of AGM or Lit-Ion units.
I'm making my own 4ga cables. Hope this helps also.
Old 05-13-2016, 10:26 AM
kink04fxd's Avatar
kink04fxd
kink04fxd is offline
I'd go with an ETX-16. 320 cca. Should be plenty. The posts should be right for your bike. This is what I Run in my 82 FLH.
Old 05-13-2016, 09:14 PM
vanmor's Avatar
vanmor
vanmor is offline
My bike is not all H-D but it's set up like a FXE from the 1970's.
Old 05-13-2016, 10:37 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is online now
Received 47,778 Likes on 17,441 Posts
My old 88 never had a starting issue that wasn't related to a weak battery and that was due to the original low amp charging system. You upgrade the battery I'll strongly suggest ditching the stock shovel stator & regulator and upgrading to the evo 32amp system. Much better.....
Old 05-14-2016, 11:42 PM
vanmor's Avatar
vanmor
vanmor is offline
A friend of mine says that it has already been upgraded. How would I know ? Like everything else on this bike, it's not the stock charging system.
Old 05-15-2016, 08:49 AM
Racepres's Avatar
Racepres
Racepres is offline
How about a Picture so the folks here that actually know can have a look...
Old 05-15-2016, 05:49 PM
vanmor's Avatar
vanmor
vanmor is offline
I don't know if this helps. Seems like you would have to see the stator to tell if it's a 32 amp.
Old 05-15-2016, 06:19 PM
TwiZted Biker
Unplug the regulator and show us the pins , that'll tell.
Quick Reply: FLH Battery Tray and Battery
