Factory Spring Perches and James Valve Seals
I bought a pack of James valve guide seals. The package says not for use with factory spring perches. They seem to be a bit taller than regular valve stem seals.
The seal won't fully seat if the perch is in place. I haven't found a spring perch that is lower. Maybe sand down the seals on my belt sander ?
Update: I decided to buy a set of stock type teflon seals. They cost me $5. I would like to have used the Viton seals though.
