'71 Superglide rear wheel
I'm looking for a replacement for my aftermarket rear wheel, and would like to go back to the 40 spoke style 16" wheel.
I can't seem to find anything specific for it, but I see a lot 73'-up listings. My HD parts manual lists the rear wheel assembly as 40980-73 with fitment for '73-'80, but nothing specifically for the '71-72.
Does anyone know if there is a major difference between the '73 and up and the '71-72 wheels? I think there both 16 x 3. Thanks.
Do you still have the drum brake on the rear? Unless you are doing a 100 point restoration...I would use a 73 up wheel and a disc brake.
Same rear wheel used on 1972 and earlier (at least to 1966) big twins.
Keep in mind FX stands for,
F=FLH
X= XLCH.
From the neck back is FLH, front end XLCH.
Here is mine.... This is the correct rear setup.
Received 47,790 Likes
