No power at switch on a 76 flh
Bike cranked and ran. Turned it off and on again at the and lost power to the dash and neutral light and it wouldn't start. Got it home on a trailer a after that 3 hour ride home it it had power again. Turned it off and on again, it was fine then tried it again and nothing, just bought the bike. Ground up restore and all of the connections are tight. Replaced the switch to have a key for the thing and was hoping that might be the problem but it wasn't. It seems I had almost the same issue with my old 78 and it was the starter solenoid being stuck but that was so long ago I don't remember. Any answers? oh yeah, it has power to the horn and lights.
The Bike has a Short to ground and is tripping the main Breaker
The ain breaker is either under the dash mount or, someone has put it on the pos of the battery [I do]. Power from pos post of battery, to main breaker, to hot side of ignition switch..
WHoa!!! Power to Horn and lights??? Who wired that one..The Horn gets power from the same breaker the ignition does...generally, the lights have their own...Both are fed fro the Key on position from the keyswitch...
If [IF] your bike has 4 Breakers..they will be Main [from battery to Ignition switch], Ignition circuit [from key-on position to Ignition and Starter circuitry], Accy [from key on position to Horn/turn signals etc] and...Lights [from Lights on Ignition position of course to lights]
Or Fry the wiring by jumping the thing!!! Easier to find that way!!!!!
There should be one 30 amp main breaker, and three 15 amp breakers: accessory, ignition and lights.
The horn should be powered by the accessory breaker, the lights should be powered by the lights breaker.
The ignition and starter solenoid circuit are powered by the ignition breaker.
Does the starter crank the engine?
Check the voltage at each breaker, you should read system voltage on each side of the breaker.
You don`t know if it is a short or an open circuit, or possibly a failure of an ignition system component.
You can fumble around and guess or troubleshoot...
Systematic troubleshooting:
Turn the ignition switch on.
With your multimeter, check the voltage at each breaker, they should all read system voltage, at both posts on the breaker.
What is the model and year of the bike?
