Classic runs only w choke out deal
1970 shovel , has a rebuilt s&s on it , fixed this issue on a dyna before , but this time all the rubber looks good to the intake man back the jets look good. So don't feel like fking w it this time any sugestions as to a good fit simple and easy new carb to try ie muniki S&s stock . What is considered by the masses to be the best .
By fcking with it,you mean proper adj? Or does it mean you've done everything you could to figure it out AND you know what you are doing? These are good carbs I have no problems with mine ,I run a super ""E"" on my 77 sporty, basically same tech as your shovel,if it is a bad carb ( bad rebuild probably) I say option 1.re-rebuild it with anew kit or option 2.buy another S&S or option 3. Send the carb to S&S to rebuild still cheaper than new and basically new and done right.If you really just don't want an S&S for whatever reason spend$ on another brand but mostly these are great carbs.
parts eeter
07-30-2014 01:27 PM
