No spark need help
No spark need help
OK guys they said I should post this here I was charging my 74 xlh 1000 got called in to work and did not unhook charger and it rained out when I got home I checked it the charger was fried and bike will not start turns over no spark at plugs I looked at points moved then with screwdriver and have spark there changed the coil and kill switch still no spark get a clicking sound from one of the breakers checked battery got 12.2 v when I try to start it drops to 10.3 no knowledge of electrical so here I am can anyone lead me in the right direction of where to go from here
Sounds like a bad battery to me. 12.2 volts isn't enough for a fully charged battery, you should have about 13.2, and if it's dropping to 10.3 when you hit the starter button that's not enough to turn the motor over.
Put a new battery in it first. You can't analyze any other electrical issues without a fully charged battery. It will probably fire up then.
In the future, when charging the battery, it's a good idea to disconnect the ground wire.
Received 4,926 Likes
