81 FLT Transmission to Final chain bath leak
81 FLT Transmission to Secondary chain bath leak
I have an 81 FLT Tour Glide.
The transmission oil is leaking into the rear chain oil bath. What is the most probable cause and what is the recommended repair?
How do I know it is leaking into the oil bath?
1. I fill the transmission to the proper level.
2. I have never manually added oil to the chain bath yet between rides (sitting idle for a week) it fills up.
2. I drained the bath to the bottom of the inspection plug near the bottom and toward the rear of the bath, which should be the normal level, then replaced the plug and let the bike sit for a little more than a week (no time to ride).
3. I opened the plug and clean oil flowed out.
4. Checked the transmission level and it was down.
Thanks in advance!
Thanks in advance!
I think he said transmission oil, not primary
See, that's the thing, I'm not talking about the Primary Drive where one might think the oil from the transmission might leak into.
Talking about the Transmission, filling through the plug/dipstick on the right side of the bike, and that oil ending up in The Secondary Drive Chain Bath.
Oh!!!!
The seal on the output shaft of your tranny is bad!
Probably.... But, Check to ensure the vent is clear before you tear it apart
Edit; The vent hose comes off a fitting on the trans cover...look between the clutch arm and the starter motor...
If ya "loose" the bath, LMK...I love mine... I will Cry when I can't replace it...
