1978 Lowrider will not crank or start. New battery lights work. Help me
Old 09-04-2016, 02:21 PM
John LaRoe's Avatar
John LaRoe
John LaRoe is offline
Stage II
Default 1978 Lowrider will not crank or start. New battery lights work. Help me
I have a 1978 lowrider shovelhead fxs. It was my father in laws bike. He had it stored in my garage for about 2 years. Well I changed the battery and the lights work. Tries starting it and it started to crank. The ground wire smoked a bit. Took the battery out to make sure everything was ok. Put the battery back in and no crank but still have lights. Any ideas?
Old 09-04-2016, 02:41 PM
John LaRoe's Avatar
John LaRoe
Stage II
I would really appreciate any help or could get as I don't know a ton about fixing bikes. Thank you in advance.
Old 09-04-2016, 07:16 PM
E-Cigrettman's Avatar
E-Cigrettman
E-Cigrettman is offline
Are you saying that the bike will turn over but not fire up or not turn over at all ?
Old 09-05-2016, 07:44 AM
feguy1's Avatar
feguy1
feguy1 is offline
Starter relay. big troublemaker. I eliminated mine from the circuit.
Old 09-05-2016, 11:10 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,201 Likes on 1,478 Posts
Sat for 2 years....
Change the gas (in the tanks and drop the carb bowl and get that gas out as well)
Remove and clean spark plugs (spray a little bit of WD-40 in the cylinders)
Change oil and filter
Kick the motor through a couple of time to make sure the engine will turn over.
Not a big fan of taking the starter relay out of the system. Starter relays were added in Feb 67 to provide more positive pull-in of the starter pinion gear and solenoid main contacts under a low battery condition and in general, more dependable starting.
You need to take out the battery and do a load test on it. It could be sufficient for lights but not enough to start the motor.
When it starts be prepared to have it puke some oil out the breather.
Before you take it out check tire pressure, take a good look at the tires to make sure there is no dry rot and that the tires are not cracked.
If you are serious about the bike, get a factory shop and parts manual. You need some mechanical skills to maintain old iron, or you end up paying someone a lot of your hard earned dollars.
If you go to an Indie, do some research and find the best in your area. Lot of shops out there but not many with true knowlege of these bikes. Don't waste your time at a dealership. They do not work on Shovels (at least those in my area).
Old 09-07-2016, 08:24 AM
mark43605's Avatar
mark43605
mark43605 is offline
6th Gear
Default Ignition circuit breaker
check the ignition circuit breaker if that's ok check the starter relay if that's bad replace it don't remove it from the ignition system, if that's ok check the solenoid,,,
Old 09-07-2016, 05:42 PM
83hdfxrs's Avatar
83hdfxrs
83hdfxrs is offline
I agree, drain all the gas, even the bowl. Check spark plugs, or even change them, if the ground wire is smoking make sure is properly grounded I restored a 83 shovelhead that wouldn't start I took the ground wire off cleaned them and tried it and didn't work. I went out and bought new ones and it fired right up. If it has been sitting for two years you might have to clean the carb there could be a clogged needle or something.
Old 09-09-2016, 07:57 AM
E-Cigrettman
Did you have time to mess with it and get it running ?
Old 09-15-2016, 12:55 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 6,992 Likes on 2,815 Posts
Try cleaning out the carb bowl and the jets. Squirt a little gas into the carb and crank it again.
mikekantmann
Electrical/Lighting/Alarm
09-09-2016 08:02 PM
bocody
03-09-2015 09:43 AM
blueglide88
06-16-2014 05:44 PM
nighty0619
04-06-2014 12:25 PM
draggingframe13
EVO
11
05-30-2013 09:43 PM
Quick Reply: 1978 Lowrider will not crank or start. New battery lights work. Help me
