Kicker problems on Shovelhead
'82 FLT TourGlide Shovel - added a kick starter. Dyna S dual fire ignition, S&S heads, S&S carb - newly rebuilt. Timing is set on the mark. Valve adjustment has been checked and looks right. Runs good going down the road. If it pops and doesn't start (hot or cold) you might as well give up and hit the electric starter. The engine can feel real tight when hot. Not sure if it's my technique, or if the ignition timing needs modified, but I've about given up on kicking it. It'll start right up with the electric. It has new plugs and wires. I've recently had better results cold using the choke (mixture lever) on the S&S, but even with that it's not consistent. It just doesn't seem to be getting a strong spark, or maybe not enough air? I think I've got plenty of fuel. Any suggestions?https://www.hdforums.com/forum/image...s/icon_eek.gif
I don't primer kick at all when it's hot...starts 1 kick just about every time with the throttle 1/4 open.... but I have cv40 though.
@E-Cigrettman
I haven't been kicking it through with the switch off at all, hot or cold. That sounds like something I need to start trying. I may try to retard the spark a little too. It's just weird how I might get one good pop, and if it doesn't start then, it seems like it will never pop again, so by then I'm out of breath, sweating, and glad to sit down and just push the button, and kaboom, it's running.
Funny how what use to be everyday, is now much harder. Yea I went out to my 80 FXB a while back and thought all was good right up to the point she almost put me over the seat, yea it hurt my knee. 2 more kicks and she was golden.
Point proved, now I just push the button.
After 30 years I remember why electric start is not bad at all.
@E-Cigrettman
I doubt that you're flooding it, but the next time is goes past 4 or 5 tries hot, turn the ignition off, open the throttle wide and kick it through 3 times , holding the throttle open wide. Then turn the ignition on and kick it through with minimal throttle opening. It sounds counter intuitive, kicking through with the throttle open, but that method is supposed to clear the cylinders for the next try at starting. (Don't twist the throttle at all once you've opened it up during this time, so that the accelerator pump isn't squirting fuel while you're 'clearing the cylinders.')
(That's an aftermarket kick starter kit. I wonder if it's got enough ratio to turn the motor aggressively enough?)
