only one cylinder fires on startup
Old 10-09-2016, 05:16 PM
gil57usa's Avatar
gil57usa
gil57usa is offline
5th Gear
Default only one cylinder fires on startup
'81 Shovelhead, 10:1 compression, stock cam, S&S "E", Power arc single fire ignition w/ VOES installed, 2" drag pipes. When the engine first starts, it seems to only fire on the front cylinder until it starts to warm up. After a few minutes the rear cylinder starts to fire. After the bike has run for awhile, it starts normally. No issues with misfiring, acceleration or power. The ignition is set up for multi-fire. I thought maybe a valve wasn't closing so I adjusted the pushrods. Timing is set properly. Any ideas?
Edit/Delete Message
Old 10-09-2016, 09:31 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
I am Trying to figure out how it is Single fire ...but set up for "multi fire"..?? BTW...Never gonna run correctly with 2" pipes of any kind...But...I know from experience that falls on deaf ears...I'll just say...Tole Ya....
Old 10-16-2016, 07:30 PM
gil57usa's Avatar
gil57usa
gil57usa is offline
5th Gear
The cylinders fire individually, hence single fire.
On each compression stroke they fire at the appropriate advance timing, again at tdc and again at 5 degrees after tdc. Hence multi fire.
Old 10-16-2016, 07:33 PM
gil57usa's Avatar
gil57usa
gil57usa is offline
5th Gear
There are anti-reversion cones at the flange end of the pipe.
Ultrahog07
EVO
11
07-31-2014 01:06 PM
Huskerjim
Exhaust System Topics
13
12-12-2013 05:52 PM
neverdown
08-08-2012 07:45 PM
Doug S
EVO
09-08-2011 07:41 PM
srob
05-22-2006 07:02 PM
Quick Reply: only one cylinder fires on startup
