F.n.g.
Old 10-10-2016, 04:46 PM
tim74's Avatar
tim74
tim74 is offline
Stage I
Default F.n.g.
Hi Folks. Tim74 here from Elyria Ohio. just want to say Hi and am wondering if there is anyway to balance a 74 shovel without having to take the engine all apart? Am installing new 0.050 over pistons and the engine vibrated bad with the 0.040's. Hands would go numb after 20 minutes of riding. Saying thanks in advance.
Old 10-10-2016, 06:06 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
answer is NO it needs to be completely disassembled to re balance
Attached Thumbnails F.n.g.-2015-09-23-15.03.02.jpg   F.n.g.-2015-09-23-16.00.27.jpg
Old 10-11-2016, 10:09 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,220 Likes on 1,483 Posts
Like jihnzjz has said, not possible because it involves the flywheels.
That said, is the engine in or out of the frame? Might be time to check for a cracked frame if the vibration is really bad. Might be time to ensure that the engine was properly installed in the frame and tightened down in proper sequence.
Old 10-12-2016, 11:03 PM
Squidbilly*'s Avatar
Squidbilly*
Squidbilly* is offline
You probably already been this far in the disassembly,
A cracked or broke top motor mount will make it shake like a dog shittin razor blades,
Other than that the cases have to be split,
Welcome from up the road,
XFXDX
Engine Mechanical Topics
04-03-2022 09:33 AM
1200efi
03-18-2013 08:14 AM
hoethree
02-27-2012 11:30 AM
py-r8
12-06-2008 10:30 PM
TowJam
VRSC Models
10-17-2007 04:17 PM
Quick Reply: F.n.g.
