1982 fxr
No...I doubt it...When you replace the fork, look at how it works.
The Fork if adjusted too close to the shaft where the Pushrod comes out...it may contact it, and break it! Solution for this is to put more pushrod into the right side of the case. I have one that comes to me where there is Not alot of pushrod on the clutch side anymore [AM clutch] oh well...Needs to be enough on the "fork side" to ensure the fork can't contact the shaft...
If ya Need to...Drop ,me a PM
1982 fxr
Thank you that will help out a lot. I have more problems to figure out. I went to tear it apart and found that the pushrod adjustment screw wont turn so I assume my pushrod has welded it's self. Can I take the tyranny cover off with tension on the pushrod or do you have a idea on how to free it up.
1982 fxr
[QUOTE=Richard Lanois;15675393]Thank you that will help out a lot. I have more problems to figure out. I went to tear it apart and found that the pushrod adjustment screw wont turn so I assume my pushrod has welded it's self. Can I take the tranny cover off with tension on the pushrod or do you have a idea on how to free it up. OK I just took the trans kicker cover off. All is good in there throw out bearing, shift fork and pushrod are good. The adjuster screw will not turn. Do you have any ideas on how to free it up. Thank you
1982 fxr
[QUOTE=Racepres;15675925]Hmmm???
never had that one...Impact???
If it don't go...Force it.
if it Breaks...it needed Replaced anyway!!!!
BTW
How the hell did you adjust it if the Adjustment screw is Stuck????[/QUOTE
Sorry I posted before taking it apart. I had the shift fork break then I put a new one in. Did the adjustment by the book and about 100 miles later I thought it broke again. But it did not. I noticed it was frozen when I went to adjust it again. It was the clutch cable that snapped this time. Thank you for all your help. Your the best.
BTW
01Sled107
02-28-2018 10:49 PM
Fxr6164
03-26-2014 06:16 PM
