72 FLH resto: rear brake hub dowels. How to install?
Rear juice brake hub has 5 dowels that mate with holes in wheel. there are 10 holes in all: the other 5 get bolts.
I'm seeing threads in the empty hole and JP cycle has a pic of the dowels with no threads. Are they press fit and threads be damned?
http://www.jpcycles.com/product/240-...&totalResult=1
Received 3,221 Likes
Billl take a look at the inside of the hub where it mates to the drum. There will be 5 flat holes and 5 slightly beveled holes. The beveled holes are for the bolts (bevel matches the taper on the bolts). And it is a slight press fit to get the dowels into the flat holes. Only time there is a real problem is when the hub has been powder coated and the powder coating inside the holes needs to be removed so the dowels will fit without beating the hub.
mjmckee53
05-29-2011 10:57 AM
