Shovelhead project
shovelhead project
Here's what it looks like today. Total bottom end done on motor.
It's a shame the speedo was left on a dirt floor.
Can someone tell me the correct orientation for the crankcase guard. Does is rest on top of the motor mount as in this pic?
or underneath the mount like this.
Thanks for your help
Art
Art
Sidecar- looking good so far. Nice work! To help with your question on the guard plate- I went out and looked at my bike. Mine is a 78 FXS. It didn't have one installed, but the motor is bolted directly to the top of the lower crossmember. I'm guessing that the plate attaches to the underside of the crossmember. Hope this helps and I'm sure someone will be along shortly with a definitive answer.
Scott
Scott
sidecar91 (01-13-2017)
Skid plate goes under the motor mount and scrap the paint off both the engine and trans mounting points before you assemble things, it'll save you future headaches with loose hardware & vibration.
PS welcome to the brotherhood partner my sig bike started life the same way in the same condition .
Back on topic.OP, good luck with your build.
