How do I cut and shorten wide glide tubes?
Bill wallace (01-25-2017)
Yep, I think that's the route I'll take. Rear end is almost done. Gotta lace and true the wheel and powder coat it. Then I'll wrench on the front and get it right. Wiring and paint and should be close to done.
Btw...got the rear shocks apart to powdercoat the covers. How do those come off?
Will post pics. Gimme a few minutes. Thanks for all your help, Twizted.
You really need a manual to tear down the legs or hunt youtube for a how to video.
Dude, that's an 1980 or later FXWG front end you have, stock tube length is 24.75" and yours looks to be 4" over. Find a set of stock length tubes, leave the springs alone and I think you'll find the bike will sit pretty good when you done. The old shorter tube FL fronts sat low and rode like a lumber truck with busted springs.
You'll need to pull a leg apart to see what tube it is and get a length before you buy, there's a couple variations on the ends make a difference most aftermarket catalogs will have a picture guide to tell you what year they are.
Thanks for taking the time. I appreciate it.
Bill wallace (01-28-2017)
Yep, it's an option. Found a kit for 89 bucks. But I think I need to lose 4 inches off the front end. If I. Going to have to buy shortened tubes, might as well get 4 under instead of 2 under and a lowering kit, unless it makes a difference in ride quality and it might. Opinions welcome.
You've been told this a couple times the front you have is longer than stock for the model it came off of not just the bike & year you have. Don't get this confused or you'll buy wrong. That front had 24.something" long tubes STOCK, 72 FLH front had 20.5" stock and you don't have this front end anymore. You will have to take a leg apart and find out how long the tube is you have now then figure out do you want stock ( 24.5" tubes ) or do want to go lower ( undersize tubes ). I will strongly suggest stock length for a FXWG or 22" or 23" replacement tubes and don't screw with a lowering kit, it really trashes what little suspension it has already.
I agree with Twizted on pulling them apart to see what your dealing with here, length wise. I wouldn't machine the stainless tubes . That would just be the longest way to accomplish your goal and really throw off the next owner of your bike when he needs to go in there for repairs or upgrade.
