Shovel wiring harness recommendations?
All,
i am going to put a new wiring harness on my bike as do the rebuild. Can anyone recommend a good wiring harness kit?
I have seen this from NAMZ, which looks good:
https://www.namzcustomcycleproducts....0NCBH-01-A.pdf
Anyone know of anything similar that would be a good match?
I am also considering going a little higher tech and using one of these:
http://motogadget.com/shop/en/m-unit...sicherung.html
Which would mean creating my own custom harness, but I can do that and it might be pretty slick!
Received 3,222 Likes
Just finished wiring a buddies 75 FLH. He found his on the flea. Used the same exact color codes per the shop manual diagram. Only thing I changed was the addition of the circuit breaker off the battery (think that became standard on 78 FLH models).
Herz one from a quick search with all the sitches soldered and ready to install. Might be worth yiur time to email them for some more information.
http://www.ebay.com/itm/HANDLEBAR-WI...NYWbFk&vxp=mtr
I have installed several of these...work great ...every wire labeled...very easy to install.
http://www.ebay.com/itm/COMPACT-ELEC...38.m2548.l4275
Thanks for the links folks - some good options there to consider. I particularly like the Ultima option.
I am leaning heavily towards the Motogadget control unit at the moment, which means building a new custom loom, but thats not the end of the world as I am an ex wireman and electronic engineer
Well, all the electric on the bike worked fine - but by the time I am done with it, it will be super clean and sparkly. The old harness has been cut and shut a bit over the years and I think it will let the look of the whole bike down if I keep it.
Plus - if I rewire it, then I will "know" every inch of the electrical system and I'll know its been done as well as it possible can be. So peace of mind as well.....
Carlos Frijoles (02-03-2017)
I'm going to use the Motogadget m-unit and keep the wiring and connectors to the absolute minimum. No relays, no flashers, only one fuse. The m-unit will take care of all of that, plus add an alarm.
It will be pretty easy now I've got my head around it. Would be a different story if I wanted to rewire my Twin Cam - but you've got to love the simplicity of the shovel heads!
take the diagram you get with the wire harness to staples and blow it up 3 feet BY 2 feet its 5 bucks then buy a set of colored markers and trace ( the wiring in the correct colors ) 3 bucks - frame it with a plastic picture frame from wal mart 8 / 10 bucks when you done its great garage Art -- we have all of them ( older harleys / indians in the shop like that
