Clutch release arm - will not adjust
Old 02-15-2017, 09:43 PM
sgr60's Avatar
sgr60
sgr60 is offline
Default Clutch release arm - will not adjust
So this is actually not for a shovel, but my 84 FXST has a 4 speed in it, so I figured the shovel section was the place to check.
I just put my motor, trans and primary back onto the bike, and I went to try to adjust the clutch, and it doesn't seem to be happening correctly. When I turn the adjustment screw on the clutch basket, it has no effect on the free play of the clutch release arm on top - it just continues to swing back and forth. When the adjustment screw finally makes contact with the push rod there are only a small amount of threads left showing, and when I continue to tighten it it starts to engage the pressure plate and allows the clutch to spin, but there is still 100% free play on the release arm. What's up with that???
Old 02-16-2017, 08:51 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,050 Likes on 1,508 Posts
Wrong Pushrod?
Too many Clutch plates?
Too "fat" clutch [wrong stack height]
BTW
You did replace the throw out right??
Aligned it properly as well??
Old 02-16-2017, 09:08 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,210 Likes on 1,480 Posts
Did you take the tranny apart? Did it work before you took it apart?
Couple of thoughts...wrong pushrod, wrong adjusting screw, clutch pushrod not engaging clutch release finger (you will need to pull the right side cover to inspect) because retaining ring on pushrod assembly has come off.
Old 02-16-2017, 10:29 AM
sgr60's Avatar
sgr60
sgr60 is offline
I pulled the tranny and had the sprocket replaced, but did not open it up.
The clutch release arm was working before that.
When I re-installed everything it seemed pretty simple - just slid everything back into place - the clutch basket went right on to the tranny shaft. It didn't seem that there should be more to it than that. Did I miss something?
Old 02-16-2017, 11:21 AM
panz4ever's Avatar
panz4ever
Think you need to pull the right side cover because the pushrod is not engaging the release finger.
TwiZted Biker (02-17-2017)
Old 02-16-2017, 03:30 PM
sgr60's Avatar
sgr60
sgr60 is offline
Will give it a shot and see what's going on!
Old 02-16-2017, 05:03 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
Default clutch rod adjustment
Is main shaft (tranny ) tapered ? Is the key for the clutch basket in the proper position on the main shaft ? Early 1984
Old 02-16-2017, 06:22 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,524 Likes on 2,865 Posts
second that - the key way slid up and out and its not now in its correct location
Old 02-16-2017, 07:21 PM
sgr60's Avatar
sgr60
sgr60 is offline
It's a late 84.The key on the main shaft appeared to be in the correct place - proper height and parallel to the tapered shaft. The clutch basket slipped right on and seemed to seat properly.
I did notice that the manual made a point to say to make sure that the key didn't move - mine was rigidly in place, so not sure how it might move?
Old 02-16-2017, 10:00 PM
sgr60's Avatar
sgr60
sgr60 is offline
Well... figured this one out!
I imagine those washers go on the end of the shaft with a new snap ring to hold them in place. I assume the order is with the regular washers sandwiching the roller washer?
Quick Reply: Clutch release arm - will not adjust
