Starter drive gear an clutch ring gear together
I just finished installing a new clutch in my 1983 flh. It was a whole kit, pre-assembled basket, hub, plates, etc. from Evolution Industries. J & P website said it fit my bike. But now that it's on the bike I realize the starter drive gear is sitting right on top of the basket gear. When I try to start the bike the starter drive can't extend out. It just hits the ring gear.
I pulled the clutch out again and set it next to the stock basket and the ring gear on the new clutch is further back (towards the inner primary). The difference is about 3/8".
Is it possible to get a new starter drive, bendix I guess, that is shorter to bring it back behind that ring gear? Or have I wasted my money on this expensive (for me) new clutch and have to go back to a stock equivalent? Any other ideas?
I can post a couple pics if I can figure out how.
Thanks
Thanks
Received 3,222 Likes
Sounds as if what you have is intended for a rear chain drive. You need one for a belt drive. Looked in their vintage catalog and didn't see any specifically referenced for rear belt drives; it looks like rear chain only.
And when I went to the individual component listing of parts, they offer the shell and ring gear. It is listed as 70-84 but uses the part number (37702-70A) as reference. Won't work though for '82 and later FLH (think that is when they went to rear belt of the FLH models?). That part number is for rear chain drive. Belt drive part #is 37707-82.
Thanks for the replies!
Just to make sure (because this is my first bike and I'm probably way out of my depth here) when you say rear belt drive are you talking about the belt behind the primary case, connecting the rear wheel? If so, how does that affect that ring gear? I hope I'm calling that the correct name... it's the large gear that goes around the outside of the clutch basket.
The one connecting the clutch to the compensator sprocket is a chain though, but I think that's pretty common.
Thanks for doing that reasearch btw. I'm off to check out that part number
Does that mean that having the wider belt drive pushes the primary case outward and then the clutch ring gear would have to be moved outward too so that it would match up with the starter drive gear when it is actuated? It seems like that would make sense with what you said about the width differences, but I'm just guessing...
kink04fxd:
I'll have to check when I get home tonight. I'm not holding out much hope though, since it was an aftermarket clutch that they obviously wanted to make it look different from stock. To be honest it looks kind of out of place when I see it in my bike. But like I said, it seemed like a really good option at the time. Plus, nobody will see it once the cover's on...
Just noticed that you indicated in your first post that you got the parts from Evolution Industries. I went to their web site and saw the one they listed for Shovelheads
EV: 1006-4242 - Clutch Basket With Screw On Ring Gear Fits Big Twin 1970-Early 1984 Replaces OEM 37702-70A.
If this is what you purchased then it is definitely for a rear chain drive (OEM part # is the indicator).
