Inside the Fender??
Old 03-25-2017, 03:02 PM
lobofang's Avatar
lobofang
lobofang is offline
6th Gear
Default Inside the Fender??
Ok Still restoring this 77 FLH and almost finished. The bolts that go through the Sissy bar/saddle bags bracket and the struts screw into something on the inside of the fender on 3 or them. The 4th had a longer bolt with a nut, but i can feel the whatever it is that the rest of them are tightening into. The issue is it to long and its rubbing the rear tire. Does anyone know what the bolts are going into and if it can be replaced?
I have tried to look up parts number to see if i can find a diagram or something but this year and older is not that easy.
Old 03-25-2017, 03:17 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,917 Likes on 17,474 Posts
OEM fenders have threaded nuts welded to the inside of the fenders on the 5/16" bolts, if they are too long you have 2 choices, washers on under the head of the bolt to shorten the exposed thread inside the fenders or #2 Mr. Hacksaw and a good file and trim the bolts to the right size.
Insert's inside the fender are spot welded and non removable.
Old 03-25-2017, 04:56 PM
lobofang's Avatar
lobofang
lobofang is offline
6th Gear
Was afraid of that, thanks for the info.
Old 03-27-2017, 06:08 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,808 Likes on 3,313 Posts
Sounds like an easy fix, Get a shorter bolt....
snakeyes
09-29-2017 11:05 PM
Dannyrider
09-21-2014 04:15 AM
Rickr01
02-13-2012 04:34 PM
DirtyThirty
03-20-2011 09:49 PM
Johnnyiroc
02-09-2010 10:58 AM
Quick Reply: Inside the Fender??
