shifter conversion
Old 07-19-2007, 01:43 PM
michiganlarry's Avatar
michiganlarry
michiganlarry is offline
Default shifter conversion
I have an 84 fx that has an fl frond end on it. I have switched to forward board controls and really like it a lot better. My question is this. What all would I need to change on the trans to get rid of all that extra fx linkage and be able to go direct from the toe shifter to the trans arm? Where would be a good place to find these parts?
Larry
Old 07-21-2007, 08:39 PM
Rick1953's Avatar
Rick1953
Rick1953 is offline
Stage IV
Default RE: shifter conversion
There are a lot of Convertion kits out there
here is a lnk to just a few
http://www.cas4.com/Forward-Controls...trol-kits.html
NOTE.. It's just a link I found that shows a number of kits,
Not a personal recommendation
What I did on both the 79 and 81
Was remove Everything from the rocker on the trans forward
Plugged the holes in the primary case and ran a single rod to the forward control
This link shows the control and rod
http://www.cas4.com/Forward-Controls...rward-c-14.jpg
Note NO lower rod to connect to the old control
tdw
03-29-2020 05:08 AM
128auto
03-07-2013 07:12 PM
128auto
06-09-2011 11:33 AM
Howlinmojo
05-21-2011 11:16 PM
hondo96inch
09-19-2007 07:14 PM
Quick Reply: shifter conversion
