76 FXE oil overflowing from tank
Old 12-31-2007, 08:57 PM
wrinspect's Avatar
wrinspect
wrinspect is offline
6th Gear
Default 76 FXE oil overflowing from tank
Just picked up a 76 fxe in fair cond, needs a few thing here and there, I rode it around the streets for @ 2 miles, pull in the driveway, notices oil dripping from the tank, wiped it up, went down the block and back, stopped eng and when I pulled the filler cap off, 4-5 oz of oil came out, was it overfull or is it backing up somewhere. I kicked it over again later and it was still trying to sqeeze out of the fill cap.
Old 01-01-2008, 10:26 AM
silvergoldsmith's Avatar
silvergoldsmith
silvergoldsmith is offline
Default RE: 78 FXE oil overflowing from tank
Did someone top it off BEFORE starting?
Old 01-01-2008, 03:45 PM
wrinspect's Avatar
wrinspect
6th Gear
I'm going to drain a little, see if that helps, thanks. Having a hell of a time starting this bike, will turn over fine, but won't start when it's cold, probably need to look at the carb. Starts ok when warm.
Old 01-03-2008, 04:04 PM
pittguy's Avatar
pittguy
pittguy is offline
Most likely overserviced,sometimes automotive type oil filters play h3ll on oil systems on a HD.Bike may have had oil in crank due to extended sitting and fresh oil change done without reguards that the crank oil has to go somewhere.
Old 01-04-2008, 07:09 AM
HogBack's Avatar
HogBack
HogBack is offline
If you let your shovel sit, then open it, that will not happen. I service my own and if I ride then open it, it will so the same thing.... it has to have some pressure to make that drop in filter work...
Later
Old 01-04-2008, 08:35 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Da Gumpmeister is offline
I have to believe the bike sat and got wet sumped. Oil was then added to fill tank. Start it up, oil in sump is scavenged and tank is now too full. Momma's shovel wet sumps (I haven't taken the time to lap the check ball) Being the concientous (?) rider, she will add a 1/3 or 1/2 a qt. Get to the gas station, oil on the tank, bike, and now the ground. But I's rather clean it than rebuild it.
8541hog
06-28-2022 04:42 PM
As-21
EVO
15
04-03-2019 05:58 PM
streeteagle
10-26-2012 03:58 AM
walkerinin
08-25-2012 01:23 PM
br401k
03-20-2011 12:16 AM
Quick Reply: 76 FXE oil overflowing from tank
