Wiring question for a 74 fxe....
I am getting ready to re-wire my 74 fxe.I have the wiring diagram,and wiring kit.I have looked over the diagram(many times).I seen on paper there should be two terminal boards.On the bike I can only find one(under the seat and in front of oil bag).If there is supposed to be two where would the front boeard be located at??Right now the wiring lookes like a rats nest.All the wires look like they connect on the ignition switch.Is that correct or a fast fix?
Any advice would be great.
RE: Wiring question for a 74 fxe....
Dunno if this helps you or not.
http://www.shovelhead.us/specs/Wiring_Shovel.jpg
ORIGINAL: shovel pat
do you have one for a 47 flathead?
Received 3,220 Likes
ORIGINAL: stevodigitalfly
hey shovel Pat
Made my day, too!
Thanks for all the response.
I checked under the visor and in the headlight housing....nothin!
Thereare two holes (one one each side)and a rectangular opening top back of the headlight housing.Would that be where a terminal board would go?
Thanks again for the help.
Forgot to add, while you are in there check the GROUND for the headlight. On mine it was rivited to the bottom of the bucket and the rivit worked itself loose. Gets damn dark on a 2 lane at 1am when you loose your ground! I used a bolt and nut to fix mine.
