Points vs Electronic
RE: Points vs Electronic
ORIGINAL: alwaysarider
I have a 1980 shovel with electronic ignition. Was wondering what are the advantages or disadvantages of having one or the other - setting timing, reliability, periodic adjustment?
My 2 cents
If it runs good the way it is, leave it alone!! You wont gain much converting to points.And there is more maintenance involved with the points obviously. I took my electronic ignition (it wasn't working)out of my wide glide and installed points about 17 years ago. Now I am looking to reinstall electronic ignition. Gettin too old to keep bending over and workin on it when I should be sittin down and drinkin a cold one!!
And to answer your questions... Yes points are very reliable, Yes there is perodic maintenance but not as often as some would make you think. I have ridden over 4000 miles without adjusting before. Probably needed it sooner but still ran and started ok. And once you have the tools (ya take em with you where ever you go) and havedone ita few times, it only takes a fews minutes-if ya got a kicker or learn to tune 'by ear'!! (I never used a timing light) Other wise it can be a bitch..
Nice thing is it is easy and cheap to convert. Your stock coil will work. But remember to keep all your take off stuff. you may want to put it back on later!!!
Ride Free!!!!!!!!!!!!
There is no way, I'd take out a good working electronic iginition and replace them with points.
Of course, I wouldn't go the other way either. I still have points in my Ironhead. In 15 years, I have only replaced them once or twice. I rarely have to adjust them, either.
I use the dyna s system on my '79 shovel. It did go bad about 5 years after I put in. Put the same back in 5 years ago and no problems. I would never go to points if I had electronic ignition especially if you live in an areathat has a riding season (andthe bike sits for the winter).The short timeI had pointsthey gave me trouble.
I put points in my 81 several years ago. I liked the idea of a purely mechanical system that you could just pack a couple spares and not worry, easy roadside repair. Black boxes frightened me - plus I like to kickstart my bike and most of the electronic ignitions didn't really work well for that. I understand now there are some that are designed to work with a kicker, and I'm sort of over my fear of black boxes now. I don't ride the shovel far enough to worry about catastrophic failures anymore anyway, so I wouldn't mind trying a good electronic again.
I still like points just fine though. I'm just getting lazier
ORIGINAL: cripula
Good point on the getting stranded with the electronic ignition when it goes bad - as that is what happened to me when the 1st Dyna S went bad.
I also never knew that electronic ignition was not good witha kick start. I've had to use the kick start most of the time I have had the bike because I have always had problems with the electric start (it finally works OK now, but rode the bike for 5 or 6 years with kick only and the electronic ignition). Interesting.
