crane hi-4 single fire
Old 05-06-2008, 12:59 AM
silvergoldsmith's Avatar
silvergoldsmith
silvergoldsmith is offline
Default RE: crane hi-4 single fire
Just tryed to use my new scanner and it won't work so the best I can do for you is:
Tech Line 904-258-6174 Fax 904-258-6167 www.cranecams.com
530 Fentress Boulevard, Daytona Beach, Fl 32114
Basically what you do is use 1 coil for each cyl. using twin fire coils.
Old 05-06-2008, 09:00 AM
silvergoldsmith
Scanner worked this morning so here it is!!
Well that was useless! Brand new piece of *****
Took a photo and here it is. Camera 1 Scanner 0 and I did not waste 2+ hrs getting it with the camera. Some one is going to have to deal with me on a refund!!!
[IMG]local://upfiles/49569/B7CD885240BF4B919271B59BD84537BB.jpg[/IMG]
Old 05-06-2008, 08:00 PM
southphillyed's Avatar
southphillyed
southphillyed is offline
Thank you very much silvergoldsmith!!....I'm sure I can use it,the only difference being is that I'm using a HI-2 ignition instead of the HI-4.
Thats not to say that I might not give the Hi-4 a shot in the near future.
I called tech services at Crane today,spoke to a fellow by the name of Frank.He said all the ignition systems are on back order.He also said that some of the components used to make various products such as coils,HI-4 set ups,etc are from germany and that because of the difference between the EURO and the DOLLAR is 2.25-1....they havent been purchasing needed supplies to assemble these systems!!
I lucked out....I got the LAST HI-2 set up they had on hand......I called 4 other parts houses and they have NO coils(crane) or ignitions(crane)!!!
HImilou
Custom Models
10-17-2015 06:15 PM
shizzomynizzo
Shovelhead
06-29-2014 12:07 AM
RidemyEVO
EVO
11
06-08-2011 03:03 AM
TexasBikeBoy
EVO
05-24-2011 10:08 PM
hdbeggs
02-14-2011 02:22 PM
Quick Reply: crane hi-4 single fire
