Starter drive
RE: Starter drive
1/2 pictures
[IMG]local://upfiles/49569/8594EE5288374D9D96861BA445B52980.jpg[/IMG]
[IMG]local://upfiles/49569/919BABE54C0B446C8810DFB4537D104B.jpg[/IMG]
[IMG]local://upfiles/49569/2F92DA1EF1DB4EA59CFE303CAE29DC22.jpg[/IMG]
[IMG]local://upfiles/49569/4A019B7856344BAF8FD045170090B3C4.jpg[/IMG]
[IMG]local://upfiles/49569/F39DBB6A030C4AF5B0B0F0BFF1B05466.jpg[/IMG]
RE: Starter drive
It makes it much easier if you have a socket to fit the 2 flat sided nut -support {if its the same as my 68 shovel} I made one from a 3/8 drive socket {3/4 size I think} and some machine work.
Be careful not to pull the jack shaft from the inner gear {again assuming its similar to the prestolite system} the gear and thrust washer will then fall inside the adapter housing.
84 Evo StarterBasic Starter Trouble Shotting states that a whin thru is caused by a worn starter clu
Dragon Rider
EVO
04-21-2008 01:44 AM
