carb or something else?
I have an 83 FLH with a keihin carb. \\; I just put new slash cut pipes with mufflers on it. \\; The other day after I pulled into my driveway I noticed that it was puffing out white/gray smoke from the exhaust. \\; I talked to someone who is \\;very knowledgable with shovels and pans about it and was told to try to adjust the carb, and if i couldn't get the exhaust to clear up, then to change the jet. \\; I tinkered with the carb a bit but it didn`t seem to help. \\; I'm wondering if this is a carb problem or something else. \\; Any help would be appreciated. \\;
RE: carb or something else?
Take a look at the spark plugs to see the color: White is to lean, black or sooted to fat, \\; tan / light brown just right. \\;
If you can afford it go with the S&\\;S "E" you will be very pleased with the improved performance and jetting will be much simpler, you will be able to adjust not only the high speed jet but also the intermediate jet. \\;  \\;
2012-Peanut
08-21-2012 07:57 AM
