I put on the kicker cover and now the throwout bearing lever isn't moving.Is their an adjustment on it or is their a way to put it on without the throwout bearing jammig up.Did it before didn't have a problem.Thanks for your time.
I am assuming you still have the late style wafer throw out bearing. \\;\\\\\\; Place it \\;in the cover against the release fingers with the push rod attached. \\;\\\\\\; Using the pushrod as a guide place the cover on the transmission. \\;\\\\\\; I keep the fill plug out so I can check to see if everything lined up.
