Pix of your shovels....
#1192
Received 3,222 Likes
#1193
#1194
This is my 83 fxrs shovelhead but someone put Evo parts on it. I call her " EVOHEAD" It has STD dual plug heads on with 3 angle valve job, port and polished, nitrated valves, .485 lift cam, shorty E carb, twin tec ignition, S&S proformance hydraulic lifters kit, arrowhead 2.0 kw starter, 600 CCA battery, tp engineering 5 speed transmission, oil breather port enlarged, rear belt drive, flat top pistons, chrome molly piston rings, Evo style clutch, and primary, upgraded not sure band hvhp oil pump, voes, and soon to be an ultima wiring harness.
#1196
Picked up my barn find a few months ago. First shovel, love it. Was in need of TLC as some do.
PO managed to spill DOT 3 everywhere, so new paint was in order. New fluids, brakes, bearings, h/light, cables, wiring, etc etc.
Sundry issues coming and going as you'd expect with a 34 year old bike. Essentially in stock condition.
#1198
#1199
Dont know what happen to my pics, so try this again, heres my numbers matching 75 FLH that has been sittin for 15+ years brought her to a good home on 04/20/16
Welcome home 04/20/16
Checkin things out
Needs a little bit of work to be road worthy again
PO said all fluids were drained and stored properly. Gas tank looks like new inside, oil tank a little gummy but cleaned up well, even the carb was clean inside, kudos to the prior owner, oh yeah and may he rest in peace knowing im bringing her back to life.
Checkin things out
