Oil pressure gauge
I'm not going to argue the point, but you're wrong KT. Of the MANY shovels I've owned, I've never had one go over 30 +/- cold, even with a S&S pump.
Is there anyone out there besides KT with a hundred pounds of pressure at start-up? I might be wrong. I don't even get 100 on my 96" Twin Cam and EVO drag bike. Just went and checked.
Back in the 70's, I built a '66 shovel and ran 60 wt. in it year-round (I live in So. Cal). Oil pressure would go up to 80 pounds when cold and at high idle.
If I would rev it up from there the oil pressure just kept on climbing. As it warmed up, the pressure would come down so I waited until I could drive it slowly without pegging the gauge. Once it warmed up, it would run about 25-30 pounds cruising around and 5-8 pounds at idle.
